Geoff_Slade
- Mar 31, 2002
My front offside indicator lens (the whole unit) fell off on the outside lane of the M1 today. Needless to say I didn't stop to recover it! It had become loose before (problem started after I'd had a new front wing fitted). I've got a few questions;
Eurocar parts and German Swedish French sell replacement lenses. How do these compare in terms of quality and fit with genuine MB.
Any ideas re price of the genuine part (non-genuine appear to be in the order of £9 - £12).
Are the clear lenses from the post 94 W124s the same size and fitting as the amber lenses (might be an opportune moment to swap!)
As far as I can remember when I last tried to put it back in place the lens fits by means of two plastic lugs locating into two holes in plastic fitments next to the front lights. These plastic fitments appear to be located by bolts. The lower one of the fitments has the whole of the fitting hole revealed whereas the top one only has part of the fitting hole showing. Question is should the whole of the fitting hole on the top fitment be showing? If yes this might explain why I had difficulty fitting the lens the last time it fell out and also why the top lug snapped.
Finally there are two electrical connectors now hanging loose in the wing opening. One has two mail pins the other two female. Do both of these connect to the new unit?
Any help and advice gratefully received
