stephenson
- Apr 9, 2005
My 1993 220TE ground to a halt yesterday. The AA man found that fuel was not getting pumped through. He checked what he thought was the fuel pump relay and said he could hear it clicking. I'm not sure he was looking at the right relay. This relay was behind the battery on the rhs of the ECU with a fuse on top of it. Reading past posts the fuel pump relay shares the kickdown function as well. On the LHS of the battery are two relays. The front one is black with the no. 003 545 50 05 and 4 Zyl Kickdown written on it. However it only has 4 pins so I doubt it is the fuel pump and kickdown relay. Behind this relay is a green coloured one which is more difficult to get at. Does anyone know the the correct relay and the pins to short to check if the pump is OK?
