W124 idling problem
tim124
W124 E280 Estate/1995/2.8
Vehicle is a W124 220E estate, auto, '93 K-reg, 208K miles. Problem seems to occur when the engine is warm: on slowing down and moving without use of the accelerator pedal (eg when edging forward in traffic) the engine sometimes revs up and down (as if it's hunting for the correct idle speed) and this causes the car to 'stutter' as it moves. This happens in forward (D) and reverse. Any suggestions as to what this might be? Thanks.
47p2
Scotland
W638, W140, W220, W639 All gone but not forgotten
Maybe the stepper motor throttle body requiring a clean
The Crooner
Woodhall Spa Lincolnshire
2006 R320 cdi
A search of the forums using the words poor idle will bring up loads of posts, a few from me, about your issue.
There is no one answer, but first thing to say ids that if it occurs when hot then a the temperature sensor might be at fault.
They are cheap enough to buy from MB, and worth a try.
If that doesn't cure it you have some reading and diagnosing to do.
All the info you need is here.
Tony
jibcl500
Cambridgeshire
CL500,ML55,SLK280
On a 220 check the condition of the engine wiring loom they break up and start to cause running issues.
One test with the engine running is massage the loom from the MAF if the engine starts to stutter or stall then the loom needs replacing.
I had the same issues and managed to rewire all areas affected but it can cause damage if not sorted.
jib
With the idle,,if the revs go up and down above that of the normal idle speed, then a vacuum pipe could be off or leaking
If the idle is falling up and down below the normal idling, then a mixture or other fault
jibcl500
Cambridgeshire
CL500,ML55,SLK280
I'd put £100 on the engine loom seen it too many times before, if the MAF loom is faulty and shorting it will damage the MAF.
jib
grober
Scotland
W204 C200cdi estate
First clean the throttle body throat (where the flap is) with carburettor cleaner or a similar solvent. Remove the top of the air cleaner box( held on with clips--disconnect the maff circular connector (turn anti clockwise) remove the inlet air temperature sensor (at rear of rectangular cross engine inlet pipe- squeeze the retaining clips inwards to clear and pullout gently towards rear of car---disconnect 1/2"diam cam cover breather pipe---slacken large jubilee clip holding the flexible rubber connection to the large metal throttle body ----pull and wiggle the entire assembly towards the offside of the car ( where the driver sits) and you will have good access. You will see the 2 hooks on the cam cover that the cross pipe attaches to when you do this-catch the two rubber mounts also.
p.s. may not be the cause but costs virtually nothing to do as a first attempt to cure your problem.
S80
North Lincolnshire
None at the monent, but there's an OM642 in the Jeep Grand Cherokee!
jib
And I'll put a £25 side bet on the 'evaporative loss' purge valve sticking open :D
Sits on the LH front inner wheel arch and has 'MOT' written on one of the ports (towards the motor). Try blocking off (sealing) the pipe end connected to the 'MOT' port (I used a bit of rubber glove!).
Any more bets, only £25 a time,,I will hold the money :D
S80
North Lincolnshire
"'Oh why don't we play cards for her', he sneerily replied,
'And just to make it interesting, we'll have a shilling on the side'" :p
T
tim124
Further developments: engine actually 'stalled' (ie it just died on me) at a traffic junction, after running OK for about 15 minutes on the road (thus fulloy warmed up). No problem starting the engine, but something is obviously wrong, because it happened again later the same day when the engine was not fully warmed up. Still want to bet that £100 on the wiring loom?
T
tim124
Thanks everyone. Have taken out second mortgage to purchase a new loom and AMM, to be fitted by Indie next week. Will let you know if this deals with the problem (and you can then collect on the bets!).
coker
Orpington
Only just logged on and saw your problem - It sounds very similar to my E320 a while back - answer was regeneration valve!
jibcl500
Cambridgeshire
CL500,ML55,SLK280
I assume you identified the loom as being the problem prior to buying a new loom?
jib
kth286
E320 Coupe 95
jib
I was also thinking that - spooky eh !
A code reading would have been good as a first step.
S80
North Lincolnshire
I must say that if the loom on my 280E ever packs up, I won't be shelling out the £500-odd pounds on a bunch of wires and connectors :mad:
It'll be either a DIY repair or Grim Reaper time....
Of all the many cars I've owned during the last 30 years or so, I can't recall ever having to replace a wiring harness in this way - not even on Citroëns :)
Shame on you, M-B.
H
howellc
Hi, interested to know if you have got it sorted. I have a similar problem and the diagnostic garage approach is getting expensive. Any help appreciated ??
