I am looking for the correct socket for my Carat Duchatelet locking nuts. Wheel has a puncture but i don't have the socket.Any help most appreciated.Thanks
I don't think you'll find a key for the locking wheel bolts. If that's the case, the simplest way to remove them is to find a socket that nearly fits, hammer it over the locking wheel nut, take it out and chuck it away. If you've got a vice and a hammer you should be able to take the bolt out of the socket and then do all four
Then you can throw the lot away and use standard bolts - or buy a new set of locking wheel bolts...
