SNST
My 95 TE280 sounds very happy. The oil pressure gauge suggests it shouldn't be! Problem has started in last week.
When hot, the pressure at 600rpm showed zero a few days ago. Now goes to zero at less than 1000rpm on idle, but not under power, so obviously the problem is getting worse. I have left it idling for several minutes, listening VERY carefully, but no untoward noises either at idle or under load.
Cam lobes have good oil cover & throw off some drips at idle, much more on increase in revs, so the oil seems to be there in at least adequate quantity.
I know I have an oil leak near the filter housing, but can't see where without significant dissassembly, so I've ignored it for a long time.
Does anyone know how long the engine will put up with ACTUAL zero pressure at idle before noise/damage shows up? Has it already shown that it must be the sender or gauge?
How easy is it to fit a pressure gauge? Is it realistic to fit a tapping to the top of the filter cover?
I'm trying to prove it is the sender, prior to 200 mile trip I have to make tomorrow.
PS Oil is clean & 1st thing I did was fit new MB filter.
204000m on the clock
Any advice & experiences welcome! I will keep board up to date on results
