W124 max heating, like it or not
DavidBlake
Hants
My 300CE heating will only deliver maximum heat, even with the temp selector wheels on the climate control set to minimum, or off.
Does any body have experience of this and know the gremlin?
C220GJS
Shotts, Scotland.
1995 W202 C220 Elegance
The heating valves default to fully open when power to the duovalve/monovalve solenoid controls is lost , check your heater fuses, the bullet type fuses fitted to your car are a known problem area , if you find this is the problem it's best to replace all the fuses and clean up the contacts in the box while you are at it.
Cheers Geo.:)
D
DavidBlake
Hants
Thanks for your help, the problem is now intermittent, so I think I have a dodgy supply to the duo valve. It always happens to both sides which seems to rule out a mechanical problem with the valve. I will check all the connections and the supply.
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
Max Power heating
Most of the time it's the infamous Duovalve but there's another possibility too: there's a sensor up in the interior light assembly with an air pump that pulls air past the sensor. If this fails or is blocked then the heating tends to go full hot
Use a wallpaper stripping scraper on the right hand side of the light assembly to push back the spring clips and the unit will come out of the headlining. You'll see a rubber tube going off into the headlining - it goes down the A pillar to the pump in the dash. Clean the sensor vent & check the pump is working
But I still think it's the Duovalve..
Nick Froome
www.w124.co.uk
