W124 number plate light not working
jbn
e220 coupe/1994/2.2
Hello all,
The near side number plate light isn't working despite having replaced the bulb. A search of previous posts suggests this could be a wiring problem but I can't find anything that tells me the solution. Could anyone advise?
This is normally just corrosion or oxidization of the contacts,,,have you tried cleaning the contacts, I believe that they are both wired in parallel, also check the push on spade connectors for a good contact
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
They're wired separately - one is on one side of the bulb fail system & the other, the other. So a bad number plate bulb will show on the bulb fail system
I'd suspect corroded wires / bulb holder or a broken wire leading into the tailgate at the hinge. That's a standard problem with very old W124 estates
Nick Froome
www.w124.co.uk
kth286
E320 Coupe 95
Sorry James
Just realised I have not replied to your e-mail from last weekend.
Yes - do bring it over this weekend if you still not fixed it.
Choose a time when it is not raining as I am doing some work on my car at present and we will look at yours in the open.
Leave message re prefered time.
Tel: 020 8863 9233
