My W124 300D 1990 started with the worst heating I have ever known, including series Land Rovers. Heating became progressively worse with speed.
To date I have:
1. Flushed the entire system with radflush, replaced the coolant, to no avail;
2. Replaced the thermostat.
After having done this with the temp guage at 80-85 degrees I now have no heating whatsoever; suspecting an airlock I bleed, refilled with the top rad hose lose,and once done with the engine running I loosened the heater pipe in the battery corner to allow air to escape. All to no avail.
This must be therefore be a duo valve problem or the matrix is blocked. Having taken the former apart and seen some of the gunk and put it back together, still nothing.
What do I do? Any further diags I can do with my multimeter on the valve, or is it the matrix blocked?
Any suggestions would be much appreciated!
Rich
To date I have:
Rich
