d215yq
- Mar 28, 2008
- Age
- 39
- Location
- Valencia, Spain
- 1987 W124 300D 280k miles
As per my previous posts my car has been increasingly unstable to drive particularly with high winds so had a garage check out the steerign and perform a wheel alignment which didnt seem to solve the problem.
I therefore presume it's play in the rear suspension as its the rear that tended to shift and feel very unstable at 60mph +, particularly over lumpy roads/in crosswinds.
Yesterday i did a long journey fully laden and the car started bottoming out and had practically no rear suspension over even slight bumps. Looking at it today the rear sits very low on one side, so I presume that means a spring has gone (a quick look and i coudlnt see it was obviously broken but understand its not always obvious if it breaks at one end).
I have no problem taking it to a garage to get the spring fixed but I'm just interested to hear if anything else could cause these symptoms. Also, as its been sittign at correct height for last 5 months but still unstable to drive I'm guessing its not just the spring thats the only issue here, or could a warn spring that had not yet broken cause the wandering and instability?
I only ask because in my experience some garages have been a bit lazy and if they see a broken spring they'll presume thats caused everythign and then it'll probably come back with the same wandering issue when i ideally want the whole thing sorted in one go.
Thanks,
Ben
Thanks,
Ben
