W124 sensitive accelerator
3ps
I used to have a W124 300D with cruise control, and you had to push the accelerator in a good bit for any kind of response. I understood this to be normal.
I have now acquired a 220TE. The pedal seem too sensitive. Most noticeable when reversing... stick it in reverse, it crawls along at 2mph... tap the accelerator and it goes into shuttle launch mode! It's very awkward in car parks etc I fear I will embed myself in another car soon.
Same in Drive at the lights. You just tap the acclerator and it launches itself. Even others have commented that they wouldn't like to drive the car because of it.
Is this a known problem, hopefully with a simple fix?
Thanks.
You either replace the throttle cable or take it down and lubricate the inner wire. If it is kinked then replacement is best
5pares
Suffolk
E320cdi
Theres also a plastic bearing/runner on the linkage which may no longer be round which causes this problem,check the return spring while your in there.
