W124 service advice
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by danmvv, Dec 6, 2012.
Tags:
  1. danmvv
    danmvv New Member
    Dec 6, 2012
    Your Mercedes:
    W124 200TE 1992
    I have a 1992 200te with about 177000 miles on the clock and I am planning on giving it a quick service this weekend from the looks of it it has not had one for at least 2 years. It has a noisy/tapping lifter on start up and for about 5-10mins after. So I was thinking of using an engine flush to try and solve this problem, is this a big NO NO? and should I just live with it.
  2. television
    television Always remembered RIP
    164,074
    310
    Your Mercedes:
    Give it a quick flush by all means, it cannot do any harm, follow that up with a fill of cheap oil and change it all after say 500 to 1k miles to a good quality oil
  3. MechPhil
    MechPhil Senior Member
    488
    Feb 8, 2012
    Brandfort, South Africa
    Your Mercedes:
    '87 260E
    Indeed, a good flush, carried out as per the directions on the product, can do no harm.
    Once you fill with a good quality oil, see if you can find some "valve lifter treatment". In SA, we have a product by Wynn's, and it seriously is one of the very few "mechanic in a bottle" products I recommend.
    Phil
  4. Gary Hanson
    Gary Hanson Senior Member
    206
    Mar 16, 2010
    Your Mercedes:
    A Jag. Jags are my favourite.
    I've always been wary of using engine flush after a mate used it on a CVH escort many years ago. Afterwards, he put new oil in, but when he started it, the oil light stayed on. In the end, he had to take the sump off to manually prime the oil pump. I wouldn't risk it, and would rather just do an oil change with some decent oil. If it rattles, why not just change it sooner, or if that doesn't work, replace the faulty hydraulic lifter ?
  5. OP
    danmvv
    danmvv New Member
    Dec 6, 2012
    Your Mercedes:
    W124 200TE 1992
    Thanks for the help, will let you know the results tomorrow
  6. Some guy on the internet
    Some guy on the internet Senior Member
    1,350
    9
    Jan 21, 2010
    Your Mercedes:
    A few.
  7. NW_Merc
    NW_Merc Banned
    801
    Apr 27, 2008
    Oop Norf
    Your Mercedes:
    Mercedes W202
    You could try flushing it, but there are problems with doing so sometimes as it dislodges debris and this can cause damage by lodging in other areas. So do it with caution. Landrover do use Forte Engine flush as a treatment, I've also used it regularly and havent experienced problems.
  8. Some guy on the internet
    1,350
    9
    Jan 21, 2010
    Your Mercedes:
    A few.
    TBH I've never understood engine flushing, I think it's a product & process dreamt up by automotive chemical makers to generate work & ££ for garages.
    If your car has been properly serviced with decent oil then there will be no need as it will already be clean.
    If your car has been under serviced, neglected or run on the wrong oil you risk dislodging crap & blocking oil passageways. In a case with these conditions I'd let sleeping dogs lie & just change the oil & filter, using quality parts.
  9. WG M-B
    WG M-B Senior Member Authorised Forum Supporter
    3,105
    6
    Dec 5, 2010
    North west london
    Your Mercedes:
    C63 Wagon in black
    I flush customers cars regularly. Diesel on every large service. Never ever had an issue
  10. OP
    danmvv
    danmvv New Member
    Dec 6, 2012
    Your Mercedes:
    W124 200TE 1992
    Sorry for the slow update. Should have checked to see if the sump bolt was stuck/rounded before putting the flush in but I didnt so a few days of driving with flush ensued, only about 6 miles. Garage loosened bolt and all is now good. Oil/ filter change and the wynns lifter fluid has solved my noisy engine
Share This Page
