W124 Strut mount gone ...
Discussion in 'Suspension, Steering & Brakes' started by Simon21, Jan 6, 2013.
  1. Simon21
    Simon21 Senior Member
    302
    Mar 19, 2011
    Your Mercedes:
    1988 W124 250TD
    [​IMG]
  2. brianbrian
    brianbrian Senior Member
    2,747
    181
    Sep 27, 2008
    cockney in the West Country
    Your Mercedes:
    w124 250D, SL129-deisel
    Yes well these cars are over 20 yrs old, I changed things like brake pipes,all hoses, springs, 10 yrs ago as It is still cheaper than buying a new car, I am going to do it again this summer. Hope this helps
  3. hotrodder
    hotrodder Senior Member
    894
    24
    Oct 18, 2008
    Your Mercedes:
    '93 320te, '54 ragtop beetle (in bits)
    Look on the bright side, back in the days of mk1 Escorts and the like it would have been the inner wing itself that let go as the entire mac strut made a bid for freedom. Did it 'get' the bonnet?
  4. OP
    Simon21
    302
    Mar 19, 2011
    Your Mercedes:
    1988 W124 250TD
    Bonnet is fine.
    Next - is this DIY?
  5. grober
    grober Senior Member
    2,941
    May 15, 2002
    Scotland
    Your Mercedes:
    W204 C200cdi estate
    Try this video how to refers to a R129 but principle is the same if you feel up to it .[YOUTUBE]1S33rat3YkM[/YOUTUBE]
    Personally I would use better jacking and body support. You may also want to remove the wheel for access but you must then support the lower suspension arm with a jack or blocks to prevent the spring from expanding to much. Best as 2 man job and DO THEM BOTH! while you are at it! Remember to have the car reassembled and resting on its wheels- bounce it up and down a bit too before tightening up that centre bolt.
  6. scotty2hotty81
    scotty2hotty81 Senior Member
    132
    Nov 1, 2006
    Easy job just support the lower arm to keep the spring compressed.
  7. kth286
    kth286 Senior Member
    3,067
    Nov 4, 2002
    Your Mercedes:
    E320 Coupe 95
    It would seem that your strut/damper may have almost seized solid to give that mount
    such a pounding.
    What was the quality of the ride/suspension like ?
  8. OP
    Simon21
    302
    Mar 19, 2011
    Your Mercedes:
    1988 W124 250TD
    All done, not by me but a good friend whose engineering skills are a lot better than mine. No rattles now :)
Share This Page
