I'd be grateful if anyone could provide the solution to a problem with my '92 200e W124,the tickover swings by about 75-100 rpm ( roughly 750 to 800 rpm ) when warmed up and slightly more when cold,I don't want to start replacing parts needlessly if I can. I've replaced the spark plugs and airfilter(which made no difference at all). Judging by the diagrams in the Haynes manual it's fitted with the Bosch HFM sequential fuel injection system. The previous owner had'nt changed the airfilter in a while by the look of it. There's a small plug (with wiring into the loom) in the plastic ducting from the airfilter housing to the injection which when removed has what looks like a wire 'A' with a bead on the tip,does this read air flow and if so could it be effected by dirt sucked in through a dirty filter. I thought about cleaning it with carb cleaner but wimped out in case I ruined it. PS Huge forum isn't it,didn't know so much could go wrong on Mercs.
