w124 vacumm pipe query
brens-e200
ireland
1990 230E W124, 1992 220ce
hi all
While working on my 230e ( 1990 w124) over the weekend I came across what appears to be a loose vacuum pipe but I cannot find any place to attach it to.
The vacuum switch has an electrical connection on it and is located in front of the battery compartment while the tube passes through to the engine bay.
What does the config do and should that pipe be connected to anything as it appears to have some sort of mesh/filter inserted into it
thanks in advance
brendan
MechPhil
Brandfort, South Africa
'87 260E
That looks like a breather of some sort. It allows a diapraghm type pot somewhere (possibly the cruise control) to "breathe" on it's open non-vacuum side. That's usually the only reason for an open pipe like that to have a strainer in the end.
kth286
E320 Coupe 95
hi all
thanks in advance
brendan
Are you sure the two pipes in the 2 different pictures are connected.
I ask, as there is an open ended pipe in the engine bay for the vent to the charcoal filter hidden inside the front wing.
The charcoal filter deals with the petrol fumes evaporated from the petrol tank.
brens-e200
brens-e200
ireland
hi kth286
yes it is connected into the switch as on the bottom
regards
brendan
