howeshouse
- Dec 16, 2005
Okay, it's an E280 estate, 1995, and most of it goes really well. But about a year ago it dropped to 4 cylinders. Swapping out one of the coils seemed to fix it for a while, but ever since then it hasn't really liked working on all 6.
It is always fine from cold, but when it gets warm, and most particularly when in slow traffic, it starts to miss. This is mild at first - difficult to tell whether it is one or two cylinders, but rapidly degenerates until it feels like there are only two working. At this point, the power output is a trifle low, and pressing too hard on the accelerator stalls it. But if you just feather it, it will generally keep going (albeit it at around 10-15mph, so you have to have a robust attitude to the queues behind, especially up hills). Turning the ignition off and then back again sometimes cures it completely, sometimes just for a few minutes, sometimes just a few seconds.
Trouble is that every now and then the misfires stop completely, and suddenly there are all 6 cylinders raring to go and as it is invariably in a low gear, the vehicle leaps forward like the proverbial startled greyhound. Having experienced this once, and nearly taking out a pedestrian, my wife is understandably reluctant to drive the car.
We have been given various diagnoses - the most common one is "new head gasket", but without any supporting evidence that just looks like £1,500 to spend with a significant risk that it won't cure the problem at all. A new ECU has also been mentioned: another £600 with a similar prognosis. The wiring harness was definitely dodgy, so I have changed that, along with all three coils, but I think I may be close to the limit of the number of times that we can spend upwards of £500 "just in case" it will solve the problem.
So, unless all of you experienced people can help me to find the problem, it seems inevitable that it will be just another sad E class estate on ebay "0.99 starting bid, no reserve". And it such a great car when it is going well...
