balge59
- Dec 5, 2005
- Location
- Nottingham
- 1993 190E 2.0 Automatic
hi
my 1993 300TD appears to have a problem with air con - but not a usual one...
A/C doesn't work (unsurpising..) but neither does tacho, temp gauge is wildly erratic and the transmission seems...woolly (but it does need a throttle cable fitting, which may sort that)
Current set up involves a fitted compressor, console with proper a/c control set, an extra switch in the panel (on switch?)
Problems include relays - I have an 'ELR' and 'kickdown' not 'klima' and appear to be short of several sensors.....
Latest problem is that MB dealer when emailed seemed to think the car was not originally fitted with a/c......I cant get the VIN decoded anymore, all my old links are dead
And I can't find a specifically UK wiring diagram for a 93 300TD to even start diagnosing properly
So.....can anyone point me to a wiring diagram for a/c and non a/c cars and
a VIN decoder, or info on non a/c 300TD relay set up?
Its a beaut car, but some of the electrics have been 'repaired'
Is it a bodged install, or a halfhearted repair...
cheers!
cheers!
