w124 wont start
Status
Not open for further replies.
jason mcavoy
engine refuses to start,will fire up on the first few turnes of the starter also the abs light will flicker once when cranking.fuel presure good and plenty of strong spark at coil.tried bypassing the ovp relay but still the same.the car has been playing up for a while by unsable idle and surging at cruising speed under slight load.
mjtray
Reading
Really does sound like a duff OVP relay.....surging, bad idle and ABS light coming on are classic OVP problems.
Because the OVP breaks down randomly it can cause all sorts of problems which are hard to detect.
If yours is still the original, I would change it for the sake of £45 or so. Dead easy to replace.
The originals had "Made in Austria" on them.
Good luck.
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
Could you tell me where the OVP relay is located on a 124 MJ? Have looked for it but cant find it , has it got a fues on top?
Sorry for butting in
Regards
Mike
M
Mick J
I'd like to know where the OVP relay is. I've got similar problems on my E220 [1994] I posted the problem a while back as 124 rough starting but got no replies.This might be the answer to my problem as well.
jason mcavoy
w124 non start
removed metering head and valve sprayed carburettor cleaner in metering valve.refitted head now she starts and runs okay,will a faulty ovp relay cause non start do you think?
justin1820
its behind the battery in front of the control units depending on age of vehicle and ignition type, it does hve a fuse on top and a nice little plastic lid
Mikesmerc
Co.Cork IRL
Thanks Justin,
I looked behind the plastic cover behind the battery but didnt seem to be there but will look in daylight tomorrow. 1988 230E
Regards
Mike
Ade
Dartford
Mike
It's under a black plastic cover nearest the wing at the end of the ECU
Hope this helps
Ade
Martins Strazds
New Registration
Latvia
Hi! Is it possible that this thing goes out of order ~ once in 2 or 3 weeks??? And after I leave it for some 10 hours its starts as nothing have been... or is it something else?
Thanks!
Mikesmerc
Co.Cork IRL
Found the OVP relay at lunch time where everyone said it was but hidden under a black plastic cover as Ade says. Fuse not blown though.
Regards
Mike
Status
