W125 500se How do i undo the Dechroming?!
evomad007
hi there,
I have recently purchased a 500se. At some point somone has painted all the exteriror chrome apart from the grille (not really my taste!) what would be the best way to restore the chrome?
Also the rear blind has come of its runner. Anyone have any diagrams or manuals detailing this?
Many thanks
Getting the paint off depends on how it was put on, if the surfaces were sanded it will not look good with the paint off.
I would try a sample area where the pint can be scraped off with a plastic implement, and will not damage the chrome.
If all OK underneath you could use masking tape but paint stripper shows no mercy and messy to use. Try scraping off first.
Welcome to the forum
jibcl500
Cambridgeshire
CL500,ML55,SLK280
If you can remove the trim that would be the best way to go, as Malcolm is the trim hasnt been keyed first for the paint then use paint stripped or boiling water to soften it, you might find a high pressure washer might remove most of it.
Just be careful.
jib
E
evomad007
Many Thanks guys. Il give it try this weekend and let you know how it goes.
E
evomad007
hi there,
Many thanks
W126!!! not w125!
