W126 300SE Crankshaft position sensor...where can I get one please??
D12typ
SL500 r129
Hi all, as per title, anyone know where I can get a crankshaft position sensor for the W126?
GSF said they had 2 types, sent me both and both wrong unfortunately
not fussed if it’s not OEM
No part number on the sensor but the one removed is one piece and majority of the cable is green in colour approx 50” long
DREAMER NO2
W124 2.6E M103 1989
DY12 Whats wrong with the mb dealers it will be the correct one from them.. Or try Autodoc. Post from Germany they are fast . Just had exhaust manifold gaskets for my car of them along with other parts . You do have 2 CPS on some engines one at the front one at the rear .
D
D12typ
SL500 r129
Thanks, I tried dealer this morning but will have to wait til Monday
DREAMER NO2
W124 2.6E M103 1989
D12 I think you have done the best think my friend .They will use your vin number, so your part will be the right one for your car .Thats if no one as changed the auto box ,.
star
Reading
Smart + others :)
Never changed one, ever.
star
Reading
Smart + others :)
No, never needed to stock one. Why doe the op need to change it?
D
D12typ
SL500 r129
Dreamer/Star thanks for your messages
reason for replacement is I am restoring a 300SE and I have crank but no spark, coil and Ezl have been replaced previously and I’ve checked the resistance across the cps and have 2.4ohms. Spec should be 800-1200. So obviously doesn’t fall within range of any sort. Appreciate Coil and EZL are the common issues I’m pretty certain mine lies with the CPS.
I’ve been advised that Mercedes Dorset/Poole deal in classic car parts so I’ll start there, I also explored the option of a CPS from an R129 which seem to share the same measurements of loom (just over) and depth of cps which is approx 40mm
long story short I’ll let you know how I get on. Appreciate your input gents thank you
D
D12typ
SL500 r129
Just as I thought, replaced the crankshaft sensor, my local independent motor factor managed to source me one and she’s up and running again
thanks gents
