i have been searching the posts to identify anyone that has found a solution to the same problem that i am experiencing on my 1988 300SEL. I have found a load of posts but i would appreciate an "idiots guide" to checking and testing for the problem as at the moment i'm clueless.
I am getting an imtermitant problem with the car cutting out. The car starts first time everytime in the morning and runs perfectly the problem appears to occur there after when it has been driven (although no doubt it will prove me wrong today!).
I turn the key the engine fires up but then cuts out. If i keep my foot on the accelerator it is fine but as soon as i release it it dies. Usually after holding the revs at about 1500rpm and slowly releasing the accelerator the engine stabilises at 500-750 rpm. But this can take up to 8 attempts.
I have read threads that indicate similar problems and some of the culprits could suggested are;
Over voltage resistor, MAF?, Idle sensor, ECU, Idle valve, throttle body?????
I would really appreciate some help. Also can anyone let me know if my car is fuel injected or has a carb?
best regards
Gary
best regards
Gary
