w126 420se ignition barrel
english1182
ignition barrel jammed.
spent all day trying to get key to turn to no 1 but no luck cannot disengage steering lock,are there any other ways to remove barrel without taking the dash out and changing the whole lock
You must get the key to turn to 1, that is with the steering lock disengaged. if you take out the barrel when not in 1, the steering lock will fore and you will ner get it out
First order the new barrel for you car from MB,,then spray some PTFE into the lock to get it to turn-
I can give you the fitting instructions
meanie
Oxon
It is possible with a Dremmel.
Use it to cut the steering column along the line of the retaining 'tit' & open the column up.You can then slide the steering lock out (you may have to cut the ign wiring & solder it back together after).
Did it happen suddenly?There is a chance that it is the steering lock at fault & not the barrel.
E
english1182
Thanks for that,
Have tried wd40,oil,ptfe etc,but still wont move although the first centimetre of the barrel seems quite slack as if it was snapped in two.
Will have a look at the steering column although the problem seems to be access as the fasia blocks everything.Would it be better to try and remove the steering column top end or remove the instrument panel and try and gain access that way,any ideas?
I have Emailed you some instructions.
Taking the steering column out is no mean feat
E
english1182
Thanks malcolm,
I have recieved some information from robparker at three pointed stars who says i can remove the bottom part of the dash and drill out the holding pin from the lock which should release it.I will check this out ,wish me luck.
Thanks malcolm,
Good luck :D:D:D
