smarty
Been away for a while chaps, and the motor has not been used as much as it should have been, when i open the car with the fob it seems to open ok! but when i insert the key to start, there is only a click (like the battery is flat) and then the alarm goes off, on removal of the key closeing the door and pressing the fob the cetral locking seems to labour and the rear doors seem to take longer to lock than the front, but eventually they do lock, when i ettempt the procedure again the same happens again? could this be something as simple as a flat battery,fuse or similar?. your on the clock to answer this one Malcolm! "its nice to be back lads"
