W126 Lighting ?
Ziggfreid
Brisbane, QLD
'84 280 SE
The situation is dim in my '84 280 SE.
There is no dash, console or gearshift lighting. The roof light works (manually), the door switches work since the front door lights turn on. Rear door lights do not work. The rear courtesy light switch also does nothing. Happily the glovebox light is good to go ! All the fuses check out fine. What's going on?
I find it hard to believe that all these circuits have dud wires or connections.
Is there some central loom connector or cct-breaker somewhere that I should check?? Can anyone direct me to a wiring diagram to make my life easier?
HELP !
Ziggy.
Hello and welcome,,I would have said that the little red fuse on the rear of the instrument cluster had blown
Z
Ziggfreid
Brisbane, QLD
'84 280 SE
Thanks for that Malcolm,
I'll check it out tomorrow.
ianrandom
Berks & South Devon.
1986 420SE, 1990 420SEC, 1989 2cv6.
Could it be the rheostat on the rear of the cluster if its not that fuse? It seems a common fault and easy to replace.
Yes it could be that as well
www.W140.co.uk&www.r129.co
