W126 uneven throttle at 1200rpm…
Scuff
South UK
500sec
Hello Guys.
Hope someone can help me with this problem..
I have a W126 500sec coupe 1992. The problem I’m having is, she idles lovely, drives as it should but in traffic as soon as I get to approximately 1000rpm the engine revs up and down like I’m tapping the accelerator causing the car to serge, until I get to around 1300rpm? it clears and back to normal until I slow down and hit the 1000-1300rpm. It’s driving me crazy.
I’ve just replaced the idle throttle position censor, cleaned the small inline filter in main feed to fuel distributor, new spark plugs, new leads and new distributor cap and rotor arm.
Any advice or suggestions would be very much appreciated guys.
Thanks for your time.
Scuff..
rayhennig
1991 300CE-24 Sportline
All of the best quality, I hope. These engines demand the best.
Can you read codes from the circular 9 pin diagnostic socket (pins 2&3)?
RayH
Scuff
South UK
500sec
Hi Guys.
Think I’ve found it I cleaned the in-line filter in the main feed pipe for the fuel distributor and since then it’s been fine. Fingers crossed
Thank you for your reply’s.. they are very much appreciated..
rayhennig
RayH
Badly worded. I should have said, "Can you read Duty Cycle from the circular 9 pin diagnostic socket (pins 2&3)?".
And read codes from the 8 or 16 pole diagnostic connector.
R
Scuff
South UK
500sec
R
Thank you so much.
Your advice is very much appreciated. I’ll get on it straight away.
Thanks again.
All the best.
Scuff.
rayhennig
Some procedures here on Duty Cycle. But you'll have to find the specs for your engine as this only refers to the M104 (mine) and the M119.
The procedures should be much the same.
R
  • DutyCycleIssues_HD_RayH_V 0.1.pdf
