w140 series s280 misfiring
gary2009
sandhurst berkshire
97 smoke silver s280
Hi all
Recently my dads 1997 s280 has started misfiring occasionally and i was wondering what could be causing this?
Any help would be greatly appreciated .
Many thanks
Gary
47p2
Scotland
Slk
It could be a number of items, the most common from my experience being either of or all of the following.
Faulty Coil Pack
Spark Plug(s)
Injector(s)
MAF
G
gary2009
sandhurst berkshire
How would i be able to check the coil pack and the injectors? Many thanks for such a quick reply.
Gary
47p2
Scotland
Slk
Start with the easy items....Spark plugs
The easiest way to check the coil is to swap them around
Do you know what cylinder it's misfiring on?
G
gary2009
sandhurst berkshire
im not sure il have to ask him but when i know il let you know.When he 1st told me it was misfiring i thought maybe the spark plugs so i will check those and let you know how we get on.
Gary
kth286
E320 Coupe 95
it can be the extenders under each coil to plug.
you really need to get to an independent Merc tech and he will be able to read fault codes and you will know immediately the fault without all the messing about.
where based ?
G
gary2009
sandhurst berkshire
he's based in sandhurst berkshire which is about 20 mins from reading
BlackC55
South coast
C43
It could be a broken up wiring loom to the coils too.
best get it on a star.
