W163 Auxilliary Water Pump
ferrispedro
Donaghadee, County Down
ML270 CDI
I received excellent advice on my heater/airlock woes on a previous thread which points to a faulty Aux water pump. This got me wondering what would you first notice if this pump failed?
panason1c
Somerset, UK
The most obvious fault would be that the 'Rest' function wouldnt work, (fitted to mercs that have climate control) . (the rest function allows the cabin heater to still continue working for approx 20 minutes after the engine has been shut down)
Also poor heating while waiting at traffic lights etc
Cole@MBS
www.mbssouthampton.co.uk
Just put your hand on it while in rest mode, its mounted on the side of the battery tray with rubber pipes in/out of it!!
Also a cold heater until the main engine thermostat had opened
F
ferrispedro
ML270 CDI
Its b*****ed then. I will take it off and see if the brushes have failed. If that is the case I'll measure them and as Panason1c did source replacements. Lots of washing machine, vacuum cleaner and power tool easily obtainable but first measure them. Thanks again everyone. Peter.
Very easy to sand down carbon brushes with sandpaper flat and rubbing the brushes over it,,, you must take the 4 corners off if you do this or they will stick
