You will wish you hadn't. Unless you get very stiff springs, you will lose nearly all the bump absorbing movement in the struts and be spending a lot of time on your bump rubbers. Extra stiff springs will shake the fillings out of your teeth:lol:
The only real option, if you are determined to do it, is to remove the rear struts and have the spring seats cut from the strut and re-welded in a lower position - I still think 2" is too much. This then allows the car to ride normally in a lower on road position. Front is easily dropped but, once again, you will have little suspension movement before bottoming and no way to stop that on the front.
You lost your key ? Or maybe you need a spare!
Your vehicle imobilliser does not respond anymore?
WE CAN FIX THEM ALL !! Mobile !
Save Time and Increase Profits With us !
