W163 ML270 CDI Glow Plugs issue
ldare
Swansea
2003 270ML Inspiration / 2007 R320 Sport
Both this and last winter I've had real trouble with the glow plugs on my 2003 ML270. The glow plugs have been changed, and so has the rely. In the summer the car starts perfectly, in the cold it really needs to turn over to generate enough heat and if below zero will not start at all.
Previously people have mentioned it could be fuel starvation but I believe that's not the issue.
What's the best way to both test if the glow plugs are getting power and also are there common places that fail that could be preventing them from heating up?
I've taken it to a few garages, some have said live with it, some have said they can't find a fault. The issue now is when it dropped below zero last month it wouldn't start. It started fine the next day after I opened the hood and let the sun warm it up a while first.
Louis
When you say garages have looked at the car , do you mean a good Mercedes Independent with the MB Star computer ?
mersum1es
Finland
it is not glow plug fault, that engine will start without them at those temps. Besides if your glow plug light works as usual, there is no fault in plugs.
It is 95% either leaky injectors or leak in low pressure pipelines (draws air in and air bubbles shown in clear pipes). Search O-rings and you will get plenty info... last 5% cover leaky hp-pump, pressure regulator or other fuel line problem/leak
L
ldare
Swansea
Yes, they said live with it, they said the cost to find the fault wasn't worth it
L
ldare
Swansea
We have changed the hp pump and also one fuel line with no improvement. If it was an air lock would this be affected by temp? As I say if it's over 10'c you'll not notice an issue. Noticeable below 9'c and a real issue when there's been frost or snow.
Ta
Louis
mersum1es
Finland
No air locks in these systems. Do you see air in clear lines? If no, measure injector back leak. It is typically very temp sensitive. You may try heat injectors by heat gun or hair dryer, sometimes it helps and fault pinpointed.
L
ldare
Swansea
If it's starting fine with the weather at the moment would I still have air bubbles or do I need to wait for a very cold morning to investigate? I may have missed the window now for this year.
Many Thanks
Taffy7hfa
Oxford
Hi Louis, sorry I cant say for sure why yours is struggling to fire up at the moment but thought you may find the following comment interesting, mine has had the "glow plug light stays on for 60 seconds after start up" fault for the last 3 months, which probably means I have 1 or more faulty glow plugs or possibly even a faulty relay, it's my daily driver and has 130k on the clock, I usually leave for work at around 6.30am, it has started every single morning (even the really cold ones !)within 5 seconds of turning the key, obviously I will be replacing all the glow plugs soon to eliminate the glow plug light fault, but my experience with this particular engine is that if it is otherwise healthy they are really not that reliant on glow plugs to start unless its well below freezing, it actually says as much in the owners manual. If it was mine I would be checking the low pressure fuel lines for air leaks, its a really common problem with these and can be the cause of long cranking times, and is often worse in cold weather.
mersum1es
Finland
leaky injector will not give usually air bubbles. Yes best result is got when problem is on but I think you could still find something in normal +5c morning test session. Check for bubbles or/and measure leak.
L
ldare
Swansea
This is very helpful the glow plug light doesn't stay on with me,
Ta
Louis
L
ldare
Swansea
So far we've replaced the High Pressure Fuel Pump, and I believe the 4 o rings with the pipes that connect and also the pipe which clips onto the fuel filter which if I recall goes to the high pressure pump? We'll look at the low pressure lines next.
Ta
L
ldare
Swansea
Me again lol. The low presure line goes from the low presure pump to the diesel filter and the other to the high presure filter by the looks of it? Ordered O rings, am I looking to replace both on low presure pump, 1 on filter, 1 on the rear of the injector section and should I do both on high presure pump? Ones on up pump don't look a quick job?
Louis
L
ldare
Swansea
mersum1es
Finland
you will need totally 6 0-rings 2x 264 (plus foamseals 2x267), 2x198, 215, 98, 252. As far I remember all rings are similar but part dealer surely know... There is only two pipes (left side of hp pump). You don't have shut down valve shown in pic left side of pump so your connectors are similar. Remove serpentine belt to get more space there.
L
ldare
Swansea
I replaced A6120703132 fuel line (which had new orings) a year ago but that made no different during the winter of 2017/18 - I'm going to change A6120703232 (again with new orings included) this summer and see what happens when it's cold again. I'll update when I know if its worked. (I didn't managed to just change the orings as A6120703132 was brittle and so ended up replacing the the whole line I didn't continue and just lived with it )
http://www.benzworld.org/forums/att...line-part-number-needed-2015-03-30_045741.jpg
Louis
Oddeman
ML 270 CDI
Did you check the cylinders compression, because if they does not generate enough pressure it will be hard to start even if the glow plugs works.
Oddemann
L
ldare
Swansea
  • #18
Oddemann
I didnt but I think an issue there would be noticable 365 days?
So far changed:
HP Pump
HP to LP Fuel Line
LP to Filter Fuel Line
Filter
Fuel line from Filter to back
Copper ring on a suspect injector
Just need to wait for winter to see if its cured.
Ta
Oddeman
ML 270 CDI
When the engine is running it will generate enough pressure to run. But the cold start requires a really good compression. Without a good compression nothing else will help. These are the required things to start an engine:
1 Compression
2 Glow plugs
3 Fuel
Oddemann
