Hargy78
- Mar 29, 2024
- W164 ML280, w164 ML CDI320, ‘58 220s ponton
Hi all,
I know there is a lot of discussions on cdi not starting and they’re prone to air leaks in the suction line between the tank and lift pump.
But mine seems to be a little different:
It starts easily but stops before it reaches idle.
I’ve put a 12v lift pump at the tank to overcome air leaks (before I go chassing air leaks) - it pumps freely but after trying to start the pump is dead-head. Fuel solenoid closing and stopping flow.
The tacho rises to about 1000rpm before it stops - crank angle sensor probably ok.
I’ve replaced cam shaft sensor and there is no change.
I’ve put a multi meter on the battery to check for high voltage - failed Volt Reg apparently can result in high voltage and shut the engine down. But no high voltage is recorded in the brief starting period.
The fob keys dont work the locks - immobiliser issue? But it does start briefly
So now for the history:
The vehicle is in a rough state. I was given it as it wouldnt start. Once home I tried to start it and it tried. I put about 10L diesel in it, it started and I drove off the trailer.
Took the engine covers off and found the wgr gummed up and black death over the injectors.
Cleaned up the intake, removed most of the black death carefully, unclipped injector 2 wiring and removed the diesel line. And of course the injector wouldnt come out. (#2 is leaking).
So I put the #2 injector back together, bleed the air and it starts but stops immediately.
Read about the fuel so filled the tank to full and tried lots of times but no joy.
Added 12v lift pump and found it dead heads when I try to start indicating a fuel valve is being closed.
So would you all be so kind as to offer items to check for?
Much appreciated,
Hargs
Much appreciated,
Hargs
