Gregjam
Tried to search for this but perhaps was not using the right work. In a stroke of madness and not wanting any potential problems as I only had one key I went to the dealer and parted with a lot of money for a genuine key. The manual says to put it into the ignition, turn to position 2, turn off and remove key then press and hold the lock button while pushing the open key five times. (all done within thirty seconds of removing the key).
As you can guess this had no effect. Have I done something wrong or is this something that has to be done at a dealer/specialist. Should it be done as part of the supply of the key or is it going to incur more cost.
All help gratefully appreciated.
