Rexhsu2001
- Apr 24, 2024
- Location
- Taiwan
- ML350/Diesel bluetec/2013/W166
Hi All,
I like to say thanks first.
I bought an used car last year. And experience some noise. My car is W166. And knocking noise is from front right when I stop car, push accelerator and turn left (steer wheel was trun left around 180 degrees), or turn right (steer wheel was trun right around 225 degrees).
When I push accelerator very light, sometime there would be no noise.
I had replaced stablizer link, but it did not fix this noise.
As I found some bushing cracked a little bit, so I am planning to replace front control arms(Left/right/lower/upper) together.
Also checked ball joint if there is too much clearance. After checking, there is no too much clearance.
Not sure if there is any other possibility to cause noise like this.
Would appreciate if you can provide me your valued opinion.
Rex
Rex
