W
Wingnuts
W169 A Class 2005 on series.
Mine works but somethong I find confusing, any advice please?
On early models like mine
Red lamp Off = Air Con ON
Red lamp On = Dehumidifier Off
(later versions the lamp notification is reversed )
So what does that actually mean, it seems that the a/c compressor is running in either case but windows not being dehumidified if lamp is On???
If thats right then why does the book refer to a/c On or Dehumidifier Off???
Would it be more correct to just say that A/C is on when the blowerswitch is at position 1 or higher but the dehumidifier function can be switched off?
Also seems strange that for powered air flow from the vents you have to have the a/c pump running all the time even in cooler weather where a/c is not needed?
Thanks if someone can decipher this.
