w169 common rail sensor plug
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by bigtwin, Nov 27, 2012.
  1. bigtwin
    bigtwin Banned
    964
    Apr 19, 2006
    Hi folks. My tuning chip has just arrived for Mrs BT's new (to us, 06 in reality) A180 CDi. It's hammering down outside, and a quick wet look with a torch under the bonnet is frustrating, and the search bar's barren!
    Can some kind person tell me where the plug is to speed things up? Suspect removal of airbox and/or other bits may be needed?
    Ta muchly.
  2. toby1
    toby1 Senior Member
    4,901
    170
    Mar 13, 2007
    West Berkshire
    Your Mercedes:
    1998 CL420 C140
    Aren't there any instructions?
  3. OP
    bigtwin
    bigtwin Banned
    964
    Apr 19, 2006
    Yup. "Fit to common rail sensor plug", and a pics of 170CDI/Vito/etc units, which aren't especially similar!
  4. OP
    bigtwin
    bigtwin Banned
    964
    Apr 19, 2006
    Bump! Any ideas? Had a good look - can't see it anywhere. Thinking I may have to take off the airbox and all the stuff molded to it, which is a pain in the backside??
  5. mersum1es
    mersum1es Senior Member
    1,959
    229
    Sep 25, 2010
    Finland
    Your Mercedes:
    I would recommend you to throw that 'powder box' as far as you can, but...
    usually in mercedes common rails the pressure sensor is located in the front of the fuel rail (pressure regulator is back of the rail then). A-class has some peculiar solutions to all constructions, so I cannot guide you for sure how the rail is located in the engine bay, but you should be able to find it. Follow pipelines either from high pressure pump (star shape block) or from injectors.
  6. OP
    bigtwin
    bigtwin Banned
    964
    Apr 19, 2006
    Thanks. Well, the engine is remarkably gutless for a 2L, so I thought I'd give it a go. If it's not good, I'll bung it on the W210 320 and see what happens - they seems to get some positive feedback.
    Suspect that removing a lot of plastic and pipes is necessary, so may just go straight to plan B and do the 320.
Share This Page
