W169 Instrument Pod
Biggles1957
W169 A Class CVT A180 2006 Elegance
So I'm going to replace the pixel display - anyone know how to remove the instrument pod? I see there are two little slots either side that you obviously must put a tool in but thought I'd ask first before poking random screwdrivers, bits of old coat hanger etc! Many thanks!
ZZZZ
You need two hooks, as pictured. This WIS file should help ;)
  • W169 Removing and installing instrument cluster.pdf
Adrian Thomas
2005 A Class W169 1500
Insert the two probes shown into the slots located either side of the instrument cluster with both hooks in the upright, vertical position. Twist both probes inwards towards the instruments 90 Degrees at the same time and withdraw the cluster. Do not force it..! Keep trying until the hooks properly engage and release the cluster.
