I'm just in the process of looking at issues to sort on my late grandads 93 190D. One irritating thing is the non-working sunroof.
Some time ago a golf ball landed on the roof, leaving a dent. It was removed and the roof resprayed. I seem to remember it working to some extent after the work, it doesn't work now and hasn't for at least a while.
The motor seems to work. From inside the car, pressing the switch results in a clunk and a little bit of movement in the different directions. When pressing the forward/ closing direction, the roof seems to go a little past the proper position and slightly tilt - making me think the timing may be off.
I wonder if something's worked loose and jammed from the roof repair work. Do these sound like symptoms of a typical problem? Does an out of time sunroof entirely stop it functioning / is that easy to fix?
Thank you,
Jonathan
Thank you,
Jonathan
