W202 18" AMG Wheels
henspeed
Please excuse my ignorance here
I have a standard C180 W202 with 195 x 65 x 15 tyres on steels
I have been offered a set of 18" AMG rims for a song, I dont know the J number of the wheels but they have 225's on the front and 265's on the rear
My queries are will these fit with no rubbing and what width tyre can I get away with fitting as I suspect the 265 with is a tough fat for the W202
Also will it make the car horrible to drive?
Cheers in advance
Cheers in advance
18" wheels will give you a more bumpy ride drive and you cant use 265 on the rear.
If you look in the chart you will see the max is 255 x 35
The offset is vey important and must match those in the enclosed chart
http://www.alloywheelsdirect.net/information/fitting_chart/mercedes-benz
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Check the fitment of the wheels for compatibility with a w202 as they were never available with 18" wheels the largest fitted from the factory were 17".
Also check the wheel widths as "most" AMG's had different sized front wheels to the rear.
H
henspeed
I suspect it is 8j for the front and 9j for the rear
I think I will purchase them anyhow and if no good they will go up on the bay
Do check the ET that is cast into the rear spoke
H
henspeed
I have the wheels now, the rears are 8J 18 ET35 with 265 40 18 rubber the fronts are 8J 18 ET31 with 225 40 18 rubber
Will these be OK?
Will these be OK?
They do look like they may fit according to Chris's guide;
Although as per above the 265 is too wide.
clk200
London
www.synergy-motors.com
w124 E320\E36
Will these be OK?
Are you 100% sure the rears are not 9" x 18. As the staggered setup using thos tyres was 8" front and 9" rear. Check first, as the rubbing will foul the paint on the inner arch.
