W202 Auto transmission fluid help
rumbo76
Telford, Shropshire
1998 C240 sport auto
I've had my C240 for about 6 months now, i've managed to do everything else service wise but i'm now stuck.
i cannot check the auto transmission fluid level as i have no dipstick, i'm told that the W202 don't have a dipstick just a cap for the filler tube ( which i also dont have) is there a workaround for checking fluid level? :confused:
Use a length of curtain wire where the fluid level should be 7 cm up the wire with the engine at 80c
whitenemesis
CLS55 AMG '05
You can purchase the proper dipstick on eBay.
Most of the so called genuine sticks on Ebay are no better than the wire as there is no shoulders on these copies
Pathfinder
Gourock
Inchcape on line will sell you a dipstick, you will need the P/N.
It will be a struggle to get the oil temp to 80 degrees, even after a hard drive in this weather.
rapide
west sussex
1997 E230 (no rust) 2016 volvo xc60 r/design. se. lux. nav.
no dipstick
also buy yourself a cap for the filler tube you done want anything going down there!
Yes correct when up to the right temp :D
