W202 C180 air leak?
D3AN
West Midlands
Mercedes C180 Esprit
I have a tiny air stream on the drivers side airvent when the fan speed is set on zero :) I've heard this on a couple of w202 c classes and never investigated as to what it was, has anyone experienced this and know what it is?
type49
Sounds more like headlight height adjuster. Move the dial & see if the noise changes note, if so, look for a broken violet hose, probably around the headlights if the car has had any accidents.
D3AN
D3AN
West Midlands
Thanks for the reply, will check in the morning ......
Thanks again
D3AN
D3AN
West Midlands
Thanks type49 the headlight adjuster did effect the pitch of the noise and the violet hose had broken in the washer bottle area. Appreciate the advice thanks.
type49
No problem. You can fix the cut/split with a piece of rubber vacuum pipe.
