mukhtar
- Jul 20, 2013
- Location
- Birmingham, uk
- C220 cdi/99/220 cdi
I own a 1999 W202 C220 cdi. The engine coolant level light is on. i've change the engine coolant sensor and the issue is there there. The washer level sensor works since the light comes on when the washer level goes done. I have noticed that the engine fan has never come on (engine temp has been at 90-100 deg on a couple of occasions).
I looked in the wheel arch area (passenger side). When fiddling with the harness connector to fan ECU unit, i notice the light went off temporarily, only to come back on again.
Does it sound like a problem with this connector (looks fine, no corrosion or water ingress witness marks) or the ECU itself?
Any help will be appreciated.
mukhtar
mukhtar
