Hi All,
As a long time avid Merc enthusiast (W124 Coupes are my "thing") I watch this forum regularly, however I thought I'd better register sooner or later!
In any case the trouble I have is with my daily run around. Its a 94 W202 C220D Elegance auto. (its done 150K with full MB SH) Just lately, which I assume is related to the vacuum issue, the autobox changes have been getting jerky,holding onto the 2nd-3rd change too long and the 3rd-4th change is also quite abrupt, however the syptom is only apparent under low engine loads (under heavy engine loads, eg going up a steep hill or hard acceleration all changes are as smooth as silk) Also some of the vacuum operated devices, e.g headlamp levelling etc have packed up all together. I know on the diesel the vacuum is provided by an auxilary pump, however I'm not sure whether this is the cause, as the brake servo, which is also operated by this pump works fine - the brakes are powerfull as they should be.
I'd really appreciate any suggestions of where to look for the possible cause, and how to test for "sufficient" vacuum at tickover, without any specialist tools. I had a quick peek under the bonnet of my W124 E220 Coupe, which has a very strong vacuum on tickover (finger over end of feed pipe) however that's a petrol engine, and takes its feed from the inlet manifold.
Thanks in advance,
Mark.
Thanks in advance,
Mark.
