kth286
- Nov 4, 2002
- E320 Coupe 95
phil
you need to have the correct plugs for your engine as some plugs are resistor plugs and some are non resistor plugs in other engines.
It will spoil the workings of the ECU if the wrong plug is installed.
My plugs for example are the non resistor at about £2 each from the dealer.
A lot of people have put fancy and expensive mutiple electrode plugs in this 6 cylinder 104 engine to find it just does not work properly.
On the question of leads, there are just 3 on my 6 clinder engine and they are the original ones at 169,000 miles, no problem.
They are straightforward wired leads and juat need a wipe over.
