Peterhough
- Mar 23, 2010
- 1997 C200 Elegance auto
C200 Elegance auto 1997
I have had an escalating series of electrical problems.
First symptom was an intermittently working blower. No pattern to it failing - sometimes worked straight away, other times came on unexpectedly during journey. Other times would not work at all and is now constantly off.
At the same time, passenger front window would only go down if rear door window switch was activated at the same time. Window would not go down on own switch.
Window is now stuck in down position, no clicking from window motor, no combination of window switch activation will shift it. Other three windows, sunroof, all other electrics work fine. Except ...
Intermittent wipe shows same symptoms as blower, except continues to work intermittently or comes on unexpectedly. Had a new stalk recently to cure different problem and everything worked fine for months after that.
I'm at my wit's end with this. Checked all fuses. Is there anything common to these three systems (but then why would three windows work and one not??)
Peter
Peter
