thecrookedvulture
- Dec 3, 2010
- Location
- Edinburgh
- 1997 E230 Elegance
Hi guys!
The park brake in my 1998 C250 Sport hasn't worked since I bought it. While the car was at an Indy getting the clear fuel lines changed I asked the mechanic to have a look at the mechanism and see if it needed adjusted. He told me that one of the cables had stretched to the point that it could not be adjusted.
Fair enough, I thought. Was just about to order the new cable this morning (MOT on Friday!), when I decided to go down and have a look under the rear seat (after reading a few posts on here).
Found that the two cables which, I'm guessing, go to the rear brakes were both detached from the pulley. Hooked them back up and BINGO! I have a working park brake.
I am however noticing that it only takes 2-3 clicks to completely apply it. Is this normal? I have attached a photo of the pulley system so you can have a look. It looks to me like the cable going to the passenger side brake is shorter than the right. Do I need to adjust something further?
Thanks in advance for all your help guys, this forum is genuinely brilliant and has helped me out loads recently
