W202 Rear window glass detached?
EdGasket
C180 Esprit 1999
Hi, my rear window has stopped working. I can hear the mechanism moving if I press the down button but the mechanism just seems to click off with the button in the up position. Also I can now just slide the glass up and down with my hand, like it has become detached from the mechanism which won't come up anymore.
Guess I need to strip the door and have a look but does anyone know if this is a common problem? Also is the mechanism rivited in on these cars; I've heard it is on some models?
NW_Merc
Banned
Oop Norf
Mercedes W202
Not a common problem, sounds like someone has tried to open the window when we had the really cold weather. The window has gotten stuck to the window rubber seal and come away from the bracket that holds it to the mechanism.
E
EdGasket
C180 Esprit 1999
Turns out the cable has rusted through and snapped.
The whole lot is rivited in so thats pretty much it really; what a rubbish design; the worst I've ever seen. All other cars I have worked on have always had bolt-on mechanisms. I wedged the window up with wood and it can stay like it.
Drill through the rivets and replace the window regulator. You can use bolts if you want, or a rivet gun isnt expensive or hard to use.
The 210 has window regulators that go occasionally, its not that difficult to do.
.... All other cars I have worked on have always had bolt-on mechanisms. I wedged the window up with wood and it can stay like it.
Plenty of fairly old cars have riveted in window mechanisms too. ;)
NW_Merc
Banned
Oop Norf
Mercedes W202
There's a complete window mechanism for sale on ebay, havent checked which side its for yet, it'll be pretty common to get hold of due to the number being broken for parts.
E
EdGasket
C180 Esprit 1999
Yes, thanks. I realise it can be fixed but as it's only the rear window and hardly ever used I won't bother. The riveted-in mechanism while not impossible to work with, doesn't help and imho is a rather cheap and nasty arrangement that ought not to be on a Merc.
