The wiper switch appears to be faulty in that the intermittant wipe doesn't work at all neither does the park function. It feels to me like a faulty switch particularly as the wiper will stop as I press the switch down to indicate. However reading through various threads I see there is a common dry joint problem on the N10 relay (Is this fitted to the W202) if so could someone help me to locate the relayand / or suggest a source of supply for the switch, or can the switches be taken apart and repaired
This is on a 97 C250 vin wdb202128
