W203 (2.0K-Manual)
Shanusacarabus
Leeds
Hi there,
I have a annoying issue with my car... since the warm weather started iv been driving around with windows down and the car sounds like a VW beetle ( annoying thraspy/tappy noise ) while i do this.... sounds perfect with windows up by the way...... any ideas on what this is... im guessing its not normal.
I will take her to a Merc indy garage but dont want ripping off so would like an idea beforehand
Cheers all
mikestrivens
Stockport
sounds like something in the wheels or perhaps it is the wind whistleing through the seatbelts.
Shanusacarabus
Leeds
No , im no mechanic but im 90% sure its either the engine/exhaust.... you hear it when you press the accelerator down
mikestrivens
Stockport
Does it do it when stationary?
Shanusacarabus
Leeds
No, mainly ( or more noticable ) when accelerating... the best description i can give is the noise like a VW Beetle... only not as loud
sounds like a slight blow on the exhaust. flexible pipe perhaps? or manifold/downpipe gasket? may be worth also checking the engine/gearbox mounts etc for excessive movement
Shanusacarabus
Leeds
Thanks for that..... while your on the subject of gearboxes... how noisy/clunky is the manual gearbox/clutch on this !!.... when the window is open all you can hear is clunk lol
dads c220cdi doesnt seem noisy. its notchy/clunky to use but cant say ive ever heard any noises from it to speak of, unless hes been a little rougher than usual with it! maybe its worth checking that theres enough oil in the box? and also another reason to check engine/gearbox mountings. if memory serves me correctly, there was a run on loose/snapped mountings on w203's on here a few weeks back
Shanusacarabus
Leeds
Ill look for the subject... dont suppose you know how to check oil on gearbox do ya ??
on a manual, there will be a plug, probably looks identical to the drain plug (probably fitted with an allen key or possibly a torx bit) about half way up the side of the gearbox. drivers side if memory serves me. remove this bung and with the car level, the oil should trickle out slightly or be within a couple of mm of the hole. i often just push the tip of a plastic cable tie into the box if it doesnt trickle out. they usually do start to trickle or drip oil out of the bung though when its removed
Shanusacarabus
Leeds
And how do i put oil in if it requires a top up.... also without checking the manual does anyone know what oil to use ??
usually with a bottle with a spout on to top it up. fill through the same hole you use to check the level. no idea what oil the gearbox takes im afraid.
www.ckinsurance.co.uk
