W203 270CDI V belt change
jibcl500
Cambridgeshire
CL500,ML55,SLK280
All
Just serviced a W203 270CDI and wanted to change the V belt as part of the service, Ive chenged them before on other MB's and ddint find it a problem, Problem is I cant even get my arms down the front to do it.
Does anyone know how or what the proceedure is to change it please.
jib
jibcl500
jibcl500
Cambridgeshire
CL500,ML55,SLK280
  • #2
OK, is it done from below??
jib
sixpack
Renfrew Scotland
2012 w212 220
270cdi belt
Hi jib,
I looked at changing mine 2 weeks ago, it looks like a real stinker!. There is a tensioner at about 2 O,clock from the crankshaft. It seems you turn part of it with a torx bit to release tension but as it is so hard to see, I dont even know what size it is. Dont think it would be any easier from below but you might be able to see the tensioner from there. I gave up but I was only looking at a precautionary change. Someone must have changed one, so tell us how ! .
Peter
jibcl500
jibcl500
Cambridgeshire
CL500,ML55,SLK280
I thought the process, well it would be easy if there was some space at the front to do it, but there isnt, I have multipul cuts that are now infected because I tried but gave up in the end.
Ive read somewhere 8 hours to change!!!! so I can only assume the front end comes off, or Mercedes employ skinny women to do the job.
Ive searched everywhere and cant find a solution, I will ring Mercedes tomorrow and ask them. They might put me on to the skinny bird they employ to change W203 V belts!!!
jib
whitenemesis
CLS55 AMG '05
According to WIS one must first remove;
trim panels on the cylinder head
viscous fan clutch
fan shroud
Grazed knuckles are optional but probably inevitable! :)
Ellsy Tanners
Mars
Its rediculously tight but can be done with a short double hex 17mm socket on a knuckle bar on the tensioner, ive had many a cut and sore doing these!!
jibcl500
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Thanks for the advice people. Ive just reinstalled WIS after removing it a few days ago, this time I decided to spend some time using it this morning and found it quite useful.
jib
BlackC55
South coast
C43
Do it from underneath.
No need to remove any fan shroud. It is tight but possible.
Try an a-class belt. The a 270cdi is easy compared!
