hofnerpres1
- Sep 23, 2013
- Location
- Buxton
- CLK 2006 A209 Kompressor
2006 CLK Kompressor - intermittent no start fault. I and others have "solved" this problem a number of times. The fault has the genius property of going away once a component has been changed and money has been spent. It's just done it again after replacing the ECM with a good cloned spare. Key goes in, key coil is energised - no steering lock movement ( brand new unit professionally replaced by last victim along with the EIS ). No key turn. Time to dig deeper. The fast engine CAN C is a Green/Green & White twisted pair and the digital signal and carry voltages are generated by the EIS. The factory WIS wiring diagram shows that the ECM and each module is directly connected to the CAN junction bus X63/4 ie GN/GNWH - these twisted pairs can be seen coming from all main control lumps around the car - they disappear into the wiring harness but none go through any connectors or SAMs on the way to this common junction. ( There is a second GN/GNWH pair coming from the rear ECM top multiplug and not shown on the wiring diagrams - another mystery - the pair in the front plug check out ) The EIS feeds the engine CAN C junction over a short wire pair and so supplies the system distribution bus X63/4. Mercedes tuck it away in the RHS cill channel (UK RHD cars) by the accelerator pedal - It's a bulky 100mm long double row black thing. It can be wiggled out to get better access but knee pads and extra lights will be needed. This now gives you access to do some basic testing with a simple multimeter ( see several helpful Youtube videos). It would be nice to see each pair labelled but the factory was clearly too busy. The odd one out is a three pin plug which also carries an earth - this goes to the ECM. Check the earth. Take a plug and test for voltages - you should be seeing 2.65v Can High GN and 2.35v Can Low GN/WH - the car needs to be awake - putting the key in will do that even if it doesn't turn. By leaving the EIS feed plugged in and removing the rest individually you might get lucky and be able to hear the steering lock activate as you remove a bad module connection. I think this car has stumped previous technicians since all the basic checks look good - Continuities, resistances and grounds all check out. We have one anomaly - As the EIS is plugged into the X63/4 bus block the voltages even up to 2.5v and 2.5v - odd. Plug in the ECM and now we have 1.6v and 1.6v ! Plug in the rest and each one brings it down to 0.8v - fascinating. I know what you're thinking - bad wires between the EIS supply and the Bus - voltage drop. Once again - not that simple. Get a back probe in the output from the EIS and both voltages fall together - the drop is on the whole system. Looks like we have a resistive short on the ECM or it's circuit somewhere. Found Larsk84 had a similar problem on the Scanner Danner forum but his W211 has a separate gateway module which simplifies matters a little. Looks like we know where to aim now. More digging tomorrow.
