W203 C220 CDI Lack of Power On Pickup
hellgrace5
Hello all !
I owned a W203 C220 CDI Mercedes. I have this problem. I pulled out 2 codes which are P1470 & P1403. I search around the forum and the P1470 code somewhat related to the boost controller around the turbo ? I thought of asking any professionals here to give me some more advice on these 2 codes.
rpe2
Silchester
Hi, and welcome to the forums.
As you put the engine under load, do you hear a loud woosh, or whistle?
It sounds as though your intercooler or one of your turbo pipes may have burst.
H
hellgrace5
Hi.
I heard the loud whistle and hoosh sound when under load.
i replace the intercooler yesterday because the left side plastic is cracked and leaking. And i checked every piping, there is no leakage. Still it does not solve my issue :(
rpe2
Silchester
Is your issue that the fault codes are there, or is it still lacking power?
H
hellgrace5
the fault codes and the lack of power. :cool::cool:
H
hellgrace5
@Blakey
Thanks for the info. May i know where is the vacuum boost pressure transducer located ? Is nearby the turbocharge, below air filter compartment ?
Thanks again:p
H
hellgrace5
Sorry for double post ! I have found the PRESSURE TRANSDUCER its infront of the coolant resevoir right. How do i determine if it is faulty. Thanks !
H
hellgrace5
@bump
Will very appreciate if someone enlighten me please ! Thanks in advance
Blakey
Brighton UK
Carefully take the hose off (not the one that vents via a filter to atmosphere) and suck the hose. If you can draw air up then you have a leak, if not then it's probably the sensor.
Chris.
