W203 Changing to Leather Interior
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by guitarnut, Oct 29, 2012.
  1. guitarnut
    guitarnut Guest
    I have a C220 Estate that i want to change to a leather interior. Does anyone know of any good instructions for seat removal?
    Also are the rear seats and door cards the same in the saloon and the estates?
  2. television
    television Always remembered RIP
    164,074
    310
    Your Mercedes:
    Seats come out easily, just the 10mm bolts in the bottom rails and unplug the electrics.
    I believe the door cards are the same, but the seats cannot be, someone will correct me on this
  3. JBell
    JBell Senior Member
    12,069
    3,949
    Dec 9, 2011
    Torquey
    Your Mercedes:
    C350 CDi Estate (GAD Edition)
    There was a complete interior on E-Bay a while ago was £500 IIRC
  4. gizze
    gizze Senior Member
    2,573
    21
    Sep 2, 2008
    Norfolk
    Your Mercedes:
    E350 cgi Estate & Range Rover TDV8
    I just sold an absolute mint one for £300.
    It was still nice and matte looking, even on the bolster.
    I bought it and then Fiona said that she preferred the cloth, so I decided to not bother.
    The whole thing is really is to swap, I took my interior out to clean it all properly, took me around 3 hours to take out and put back in again.
    Just make sure that if you have part electric, buy the same, otherwise you may run into issues.
    A tip. Undo the front seats, then recline them, then remove the battery cable and unplug the connectors, you can then slide them out through the back of the estate, trying to get them out through the doors is a mare.
  5. OP
    guitarnut
    guitarnut Guest
    Thanks guys, do the rear seats on the saloon fold at all?
  6. gizze
    gizze Senior Member
    2,573
    21
    Sep 2, 2008
    Norfolk
    Your Mercedes:
    The saloon seats won't fit the estate at all, so if you need an interior for an estate it doesn't matter whether the saloon interior has folding seats, the rear seats are completely different.
  7. OP
    guitarnut
    guitarnut Guest
    Thanks gizze, that saved a potential :Oops: moment.
    I'll keep looking, there is a saloon one on ebay so it's good to know that's a no go. From the looks of things i don't need the door cards as mine are black already.
  8. gizze
    gizze Senior Member
    2,573
    21
    Sep 2, 2008
    Norfolk
    Your Mercedes:
    Black what though?
    The leather door cards have leather inserts...
    [​IMG]
  9. OP
    guitarnut
    guitarnut Guest
    I have half leather already so the door cards have a black leather "pepper pot?" insert - well i think it's leather :D
    I've certainly seen cars with leather seats in this style.
    Would have bought them off you had i have known!
  10. television
    164,074
    310
    Your Mercedes:
    Do not forget that it is not that expensive to have some of your trim changed to leather,,have you asked anyone
  11. OP
    guitarnut
    guitarnut Guest
    I haven't thought of going down that route, good idea.:)
    I was hoping to for around the £300 mark cost wise.
    If it can be done within my budget can anyone recommend a seat trimmer in Yorkshire?
  12. cleverdicky
    cleverdicky Senior Member
    2,385
    Feb 25, 2009
    Your Mercedes:
    MB
    You can get complete fully made 'covers'. As per original spec.
    These dont go over your existing cloth cover but replace it.
    Its a lot of very hard work though.
    I often see very good complete interiors at breakers.
    If you can swap seats over - much easier.
Share This Page
